Results 1 to 7 of 7
Thread: GU Patrol ZD30 common rail not starting
    Jun 2019
    hi there. I have recently converted my patrol from diesel injection to common rail. now car wont start at all. I have changed the loom and computer, I have noticed if I keep pumping the hand pump that it will not stay firm it will go back to being soft. I put carby cleaner in the throttle and bang it starts but once it runs out of carby cleaner it will stop.
  2. The Following User Says Thank You to staytuned For This Useful Post:
    rusty_nail (12th June 2019)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    5 Post(s)
    Have you changed the NATS and the chip in the key to the new computer?
    45 Post(s)
    Quote Originally Posted by staytuned View Post
    Hey mate, sounds like could be air in your lines? Have you tried bleeding it?
    Jun 2019
    I have changed accelerator pedal, computer, loom and ignition barrel. But im still waiting on a airflow meter as the new loom has 5 pins and the old one has 4 so its not currently plugged in.
    Jun 2019
    yes have tried bleeding the lines even have tried gravity feeding direct diesel into the feed line to bypass the hand pump setup and still wont kick over.
    Jul 2010
    Thurgoona
    5 Post(s)
    When you turn the igniton ON with the key and all the dash lights come ON, does the flashing NATS light on top of the dash STOP flashing?
  9. The Following User Says Thank You to BillsGU For This Useful Post:
    rusty_nail (13th June 2019)
  10. #7
    45 Post(s)
    maybe its something to do with that stupid nats system they have?
