Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Tools Reqd for Wheel Bearings
    May 2016
    lower west victoria
    30 Post(s)
    This is the best thread just for Wheel Bearing adjustment.
    http://www.nissanpatrol.com.au/forum...ing-Adjustment
    You wont need the circlip pliers just to tighten the wheel bearings. Leave it on.
    Thanks so much for finding that link & doing the write up, greatly appreciated.
  2. The Following User Says Thank You to 10G For This Useful Post:
    MudRunnerTD (4th June 2019)
    Ballarat, Vic
    174 Post(s)
    Rather than a standard L shaped allan key, I have one which comes in a 1/2" socket. Makes undoing the allen bolts on the hub a lot easier - as well as allowing use of a torque wrench when at home (I don't carry a torque wrench when travelling).
    I also have steel 'protection' rings which the allen bolts hold on the outside of the hub. Don't know how much protection they offer, but in the absence of a torque wrench they help me to feel that the tightening pressure is more evenly distributed around the alloy hub. If you carry spare bearings, pre grease them & vacuum seal. Plus a suitable drift to remove old bearing cup, plus spare inner grease seal.
    A phone with a camera is very useful when anything is being pulled apart to create a record to refer to when putting it back together. An offsider to operate the camera is also very helpful as their hands wont be covered in grease!
    FWIW - I do suggest that before you leave home that you have a go at adjusting your wheel bearings so you are familiar with the task. Much easier than learning for the first time sitting in the sand, dust blowing around & bull ants wanting a piece of you!
  5. #13
    May 2016
    lower west victoria
    30 Post(s)
    I've not looked yet, what size are those allen keys???
  6. #14
    Ballarat, Vic
    174 Post(s)
    8mm on mine
  7. #15
    May 2016
    lower west victoria
    30 Post(s)
    Thanks Cuppa, much appreciated.
  8. #16
    80 Post(s)
    I also use a 1/2" drive allen socket, with a Warren Brown torque wrench as I found the micrometer type wasn't accurate at all.
