Results 1 to 10 of 11
Thread: GQ Wheel bearings
    Jul 2018
    SE Vic
    GQ Wheel bearings
    Howdy guys, got a small problem. I'm doing my wheel bearings on 91 GQ , but once I've setted bearings in at 160 odd pounds then back it off ready for lock ring but hub is way too tight to turn. Even at hand tight it takes a bit of effort to turn hub by hand. Only thing I've changed is lock nuts on hub to GU style. Any info would be appreciated, Thanks.
    Are you trying to spin with wheel on or off? Fair task with the wheel off. Whack a wheel on and see how it feels. Should be finger tight.
    Jul 2018
    SE Vic
    Found out problem with bearings, apparently the seal is round the wrong way. Mechanic told me that for some reason in patrols or just GQ you have to spin the seal around opposite way than all other cars. Last person that did bearings put seal in the wrong way and I've just followed how it looked. Sounds strange but the mechanic races GQs in winch pull events so I suppose he knows. I'll give that a try.
    Quote Originally Posted by GQJay View Post
    Have a look at this thread mate. Everything you need to know is there.
    http://www.nissanpatrol.com.au/forum...Rebuild-Thread
    Ask questions there if needed.
    Jul 2019
    I’m going to be doing the wheel bearings on GU this weekend. I saw a vid by terrain tamer where he tensioned the wheel bearings then he hit the edges of the tyre with a sledge Hamer then checked for movement. Which there was then he tightened them again.
    Is that a good method of seating them????
    Any ideas would be great. Cheers
    462 Post(s)
    Quote Originally Posted by Rustyno1 View Post
    What I do is tighten them up until theres no movement other than rotational. Then go for a drive around a few streets then jack it up and recheck.
    Jul 2019
    How tight on the rotation. Will spin a little with a push or will stop when stop
    Pushing. If that makes sense
  10. #9
    462 Post(s)
    Well if you go too tight you will fell it when spinning the wheel. So I'll tighten until then back it off a little so the wheel spins easily. But not too easy where it borderline becoming lose. If you get what I mean.
  11. #10
    Jul 2019
    That’s great. Thank you
