31st May 2019, 05:46 PM
Air con filter
Ok, while I'm waiting to sort out my castor correction I have been busy cutting out the two slots behind the glovebox. Now what filter do i need to suite the 2013 Y61 GU8 Wagon? I measured the internals depth as being 28cm from front of box to rear (internal wall). I've called around the various shops and the ones they have listed are 26cm's depth ?? Does anybody have the correct filter/part number? Yes I have trolled the forum and none of the filters I have seen have that depth.
31st May 2019 05:46 PM
31st May 2019, 05:57 PM
Moderator
timbo2410
here you go mate
http://www.nissanpatrol.com.au/forum...a-GUIV-onwards
Check out my Toy -->
Rogue Dung Beetle
31st May 2019, 06:28 PM
how the heck can you find things that quick .. i'm still trying to type with one finger thanks for that and I just called Nissan $59
just re-measured and found I had put to tape measure into the recess for the pipe at the back .. and yes it does come out at 26cm's not 28 ..
The Following User Says Thank You to timbo2410 For This Useful Post:
MudRunnerTD (31st May 2019)
31st May 2019, 08:04 PM
Moderator
timbo2410
Hahaha. I remembered the conversation and it was around "cabin filters" searched using search function and it came straight up.
Rogue Dung Beetle
