Results 1 to 3 of 3
Thread: Transfer Fuel Pump
    Jun 2015
    Perth Tapping
    Transfer Fuel Pump
    hi all, my 2007 patrol Transfer pump has blown / melted wires, going to replace with a different pump not factory as cost $$$ what would you recommend have been looking at a Goss one, Can I just plug one in and that's it or do I have to change anything as not Factory one?
    Dave
    AFAIK a non-factory pump won't work with the factory wiring unless you use a resistor to impedance match the pump windings to fool the Sub Tank Computer.
    Thats what I had to do on my '99 truck anyway.
    The resistor will depend on the pump you choose so can't help with a value.
    Other alternative is run a seperate switch and power circuit to a non-genuine pump
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    MB (9th June 2019)
    473 Post(s)
    I believe The Evil Twin is on the money there mate.
    My current 99 truck also when purchased second hand already had an aftermarket seperate switch/wiring/pump installed. (not sure which brand pump sorry).
    On slightly later model GU’s I’ve had to replace expensive OEM pumps and also dust impacted dash switches so could be a good alternative if time permits.
    You just won’t have automatic shut off when sub is empty or main full but a big red glowing switch and keeping an eye on tank guages isn’t too hard I find.
