Results 1 to 8 of 8
Thread: Stainless steel cable tie Tool
    May 2016
    lower west victoria
    30 Post(s)
    Anyone using a proper tool for stainless cable ties?
    I tried to do some with just a set of pliers and it was darn difficult. Also I couldn't cut the end of very close and the bit left sticking out of the tie is extremely sharp. I've looked on eBay for a tool and there's toms around $45-50 and then some around $100.
    I'm just wondering if anyone uses the $45 ones? Are they any good? Can anyone recommend something or some way of tightening and cutting these things without the proper tool???
    TIA.
    194 Post(s)
    I have one of the more expensive commercial ones, couple of hundred, does a great job but it is to some degree in the skill of the operator as well. Biggest issue for me is the trimming of the tail after its clipped to not get a sharp knuckle shredding edge. I fold my 'tails' over and peen them down with a hammer.
    175 Post(s)
    We use the Band-it version at work, various sizes. I've got the smaller version at home, not sure what size maybe 4mm. Bloody strong stuff, especially the 16mm+ version we use around concrete poles.
    We lifted a 1.4t pole with one layer on 12mm band and it held "Do not try this at home".
    I never actually had to use it for anything around home, but I can see how this can easily become a bush fix utility to clamp something together around chassis, or something...
    May 2016
    lower west victoria
    30 Post(s)
    I use some stainless ties on a PVC tube on my roof rack, had lots of trouble tensioning the tie with a set of pliers, darn thing just kept spinning around.
    I wonder if there is a cheaper alternative to these tools?
    I did find this - https://www.cabac.com.au/product-specs/16450505/SSTDT
    175 Post(s)
    Tried putting some gripping material under the tie? Like a bit of bike tyre tube for example? This makes it grip tighter and stops it from spinning around.
    Good trick to use with the light bar mounts on the bull bar , thanks again @Plasnart
    May 2016
    lower west victoria
    30 Post(s)
    That's a good idea Hodge, I might also try just some good old electrical tape, I reckon that might work as well.
    Just for some more info for others, here's a clip on how you can tighten SS ties without the special tools, ends up with a good result I reckon - https://www.youtube.com/watch?v=ecS2ZwjWo-g
  8. The Following User Says Thank You to 10G For This Useful Post:
    Touses (27th May 2019)
    Feb 2019
    TIA.
    Professional tool, unfortunately – professional price
    https://www.panduit.com/en/products/...ols/gs4mt.html
    Regards
  10. The Following User Says Thank You to Sgucul For This Useful Post:
    MB (27th May 2019)
  11. #8
    472 Post(s)
    Good work @Sgucul mate!
    “Panduit” in our little plastic work game too are the best by far!!
