26th May 2019, 08:52 AM
Zd30 boost control
Been a while but I’m back after a lengthy affair with a Triton...
Just bought a 2004 gu wagon and wondering if I can’t just delete the factory boost control module and fit a normal bleed valve to adjust boost. I’m a noob with anything electronic so be kind with replies please...!
GQ Wagon 4.2 carb 4inch lift of the road resting
GU Rd28 Wagon 2 inch lift on the road now daily driver
D22 Navara ZD30- in rehab pending being moved on.
26th May 2019 08:52 AM
26th May 2019, 11:05 AM
Have a search mate there is plenty written on this subject.
set your boost to say max 16psi and adjust your spool up using a
tillix valve. you will then bypass the ecu. while your at it block the egr valve.
If your IC is oily its leaking replace with a fully tigged one, youll also require a boost
and egt gauge, a must for any Di motor, plus a ecu-talk to stretch the budget even further
