Results 1 to 10 of 11
Thread: Spit cooking
    48 Post(s)
    Spit cooking
    I've had this little spit for a while and wasn't too happy about losing so much heat. At home it was OK, set up in the garage but during camping and if it was a little windy it would takes way too long...
    The only part of my job that I like. Making foreigners...
    2mm stainless steel.
  2. The Following User Says Thank You to jay see For This Useful Post:
    MB (25th May 2019)
    109 Post(s)
    Very nice mate! I have the same spit by the looks of it, but of course without the ss bling!!
  5. The Following User Says Thank You to Plasnart For This Useful Post:
    jay see (25th May 2019)
  6. #3
    mine is made from a 9 gal keg with the ends cut off pic to come
    at camp it loses heat very quickly so the Auspit works better.
    @Jaycee youll need to drill some holes in it so the fire will "draw"
    My keg spit had a SS heat shield and a tray to hold the heat beads
    at home at camp we just shovelled coals in it. never took it again
    I have about 3 of these at home, great for toasted Sanwiches lol lol
    Didnt notice yours has open ends will lose a heap of heat imo
  7. #4
    469 Post(s)
    Spit cooking
    That’s awesome Jaysee mate!
    Maybe an idea for the ends, make 2 x drop in square sheet plates that can double as fire shields over the coals for when carving time comes around?
    EDIT: Square plates would need to be slotted of course to allow the rotisserie rod and or 4 x rectangle drop in plates maybe, leaving only a slight gap vertically ?
  8. The Following 2 Users Say Thank You to MB For This Useful Post:
    jay see (25th May 2019), threedogs (25th May 2019)
  9. #5
    My BFF made one similar to yours fully enclosed but the heat beads kept
    going out so we lite them again cracked a can and started drilling holes
    still the fire stayed on. Once sorted it should cook great about 20 heat
    beads for a small butt of beef or a rolled chicken from Lennards.
    "Dont use kero infused heat beads" I also fit a temp gauge into the lid
    The tray for the heat beads should be as long as the spit housing and up
    off the base with holes in it, Ill take pics of all the components on mine to give
    you some ideas
  10. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    jay see (25th May 2019), MB (25th May 2019)
  11. #6
    109 Post(s)
    The trak for the heat beads should be as long as the spit housing and up
    you some ideas
    Whats a BFF TD?
  12. #7
    Whats a BFF TD?
    Best mate sorry.
    I used to take mine to 4x4 shops and do a spit roast for lunch
  13. The Following User Says Thank You to threedogs For This Useful Post:
    Plasnart (25th May 2019)
  14. #8
    48 Post(s)
    Yeah, I thought of doing the holes John. Will give it a run first and see how it goes. Do like the idea of the temp gauge.
    Mark. Guy at work wanted me to close off the sides with some removable sides so it could double up as an oven. Maybe later.
  15. The Following User Says Thank You to jay see For This Useful Post:
    MB (25th May 2019)
  16. #9
    469 Post(s)
    You’re all over it Jaysee Tucker Mate!
    Agreed, probably don’t want to sweat a sweet rotisserie too much oven like contained.
    Let’s be honest, at least in my world 50% of the family tucker taste probably does come from the preparation theatrics:-)
    Cover it all up too much and what’s the family point? :-)
    Simple senses critters we all are I believe
  17. The Following User Says Thank You to MB For This Useful Post:
    jay see (26th May 2019)
  18. #10
    Hers the pics of my keg spit @jaysee might get some ideas from it.
    Used to wrap everything in tinfoil and to clean just used oven cleaner then hosed out easy peasy
  19. The Following User Says Thank You to threedogs For This Useful Post:
    MB (2nd June 2019)
