15th May 2019, 03:06 PM
Expected cruising boost
DDi 3.0 (not common rail)
Does anyone know the expected unmodified boost pressure when cruising around 90 - 100 km/hr.
Alternatively, what pressures are you experiencing??
Seems I get between 9 and 12 psi without much throttle.
Checking small stuff as I have a brand new rebuild to run in.
15th May 2019 03:06 PM
15th May 2019, 03:17 PM
I have the same motor with dawes and I get about that reading. long haul at 100k sits on 10psi when crusing, so 9 to 12 sound about right. I limit it at 15psi but you really have to put the boot in to get it over 12 or so. Hope that helps. Cheers Tony
The Following User Says Thank You to 4bye4 For This Useful Post:
15th May 2019, 03:37 PM
10 @ 100 on the highway.
16 max.
The Following User Says Thank You to Mc4by For This Useful Post:
15th May 2019, 04:09 PM
X2 10psi @ 100kph is the norm what are you driving manual or auto
as that will be different revs at 100 kph
15th May 2019, 07:17 PM
So with the knowledgeable responses I am satisfied that I have it about right. Thanks to all.
