Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Is anyone running a front LSD?
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I mean it'd be an interesting experiment.. and I'd follow with interest haha.. but I just wouldn't imagine it would be very nice to drive in normal circumstances. The tighter you shimmed it the better traction you'd have but I assume the turning circle would grow as a result. Plus you may need to consider the legalities of it if it's a daily. Might upset your insurance if you come unstuck.
    80 Post(s)
    The diff is only in use if the manual hubs are locked. You have raised an interesting point with insurance. Is an auto locker roadworthy, or an e locker or air locker for that matter?
  4. #13
    Jan 2017
    South Australia
    11 Post(s)
    But just normal wheeling when you're out on the tracks.. you don't wanna be locking and unlocking your hubs all weekend. At least I don't. Normally get locked in when I get off the black stuff and stay in till I'm on my way home.
    Elockers would have to be legal. They're factory items in the cruisers. They do however only lock in under certain conditions.. ie only when low range is selected. Not sure on the auto lockers or any aftermarket jobo.
  5. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    mudnut (11th May 2019)
  6. #14
    I've been stuck a couple of times with one front wheel spinning uselessly in the breeze. I have the unit sitting there and am very curious about how they perform.
    have you tried tapping the brakes when you have one wheel spinning it gives drive to the one not spinning??
    mudnut (12th May 2019)
  8. #15
    80 Post(s)
    have you tried tapping the brakes when you have one wheel spinning it give drive to the one not spinning??
    I'm not that coordinated TD. Have tried that on sand with the hand throttle locked open. Didn't quite get it. Having an auto would make that technique easier.
    Loosing momentum is the biggest problem.
  9. The Following User Says Thank You to mudnut For This Useful Post:
    threedogs (12th May 2019)
  10. #16
    194 Post(s)
    A mate of mine had front and rear detroit lockers in a 60 series landcruiser, went anywhere as long as it was in a straight line, total pig of a thing in the bush, turning circle of a train, constantly having to stop and back up, Saw another guy with a factory LSD in the rear of a Nissan 7204wd and one of those loc-rites in the front. He liked the way it 'let go' on high friction surfaces in the bush when turning so the turning circle was pretty good, he didn't do anything super hard with it, but it worked for him - something else to consider perhaps
  11. The Following User Says Thank You to PeeBee For This Useful Post:
  12. #17
    Jul 2017
    Bundanoon, NSW
    Not sure how it would with a locked centre diff/transfer case but my Subaru Liberty GT came with front and rear LSD differentials as well a selectable centre diff from 70/30 to 50/50 LSD action.
    Don't see why an LSD in the front would be problematic as it will still allow turning/steering action as it is not locked like an auto locker.
    Would be interesting to see if anyone has put an LSD in the front of a large 4wd instead of a small turbo lounge chair...
    Greg Pointing
    Conservation, Rehabilitation & Education
    1989 GQ Patrol Wagon, TB42 Auto - Now with 2" of added lift...
    1991 Mazda MX5 - Coilovers, Exhaust, Intake, NB brakes & seats.
    2012 Mitsubishi Triton 4x4 Dual cab TDI - The Mrs truck....
  13. The Following User Says Thank You to PureCaboose For This Useful Post:
    mudnut (13th May 2019)
  14. #18
    80 Post(s)
    Quote Originally Posted by PureCaboose View Post
    Someone mentioned racers use a front LSD, but that is a different animal altogether. I wonder how tight the front LSD was shimmed in your Subaru to get a good turning circle?
