5th May 2019, 05:03 PM
Clutch Doesn't Return During Bleed
Hi Everyone,
So very confused... need advice.
While bleeding the clutch I seem to be pumping for ages and pressure doesn't return but if i leave it alone for a few minutes, the pressure eventually returns.
Background is installed new clutch, flywheel, slave and second hand master. No leaks that's obvious.
Stuck...
I wonder if the master is damaged or that i still have air in the system. Waiting for a vacuum pump to get any stubborn air pockets.
I drive a GU with a converted GQ TD42
Any other ideas?
Cheers,
Casey
Reason: Fix poor explanation
5th May 2019 05:03 PM
6th May 2019, 04:15 PM
Place a block of wood under the clutch pedal when bleeding the system, so the pedal doesn't go beyond normal operation travel and try bleeding again.
8th May 2019, 11:25 PM
Thanks for the reply. In the end i took the booster out and adjusted everything and also replaced the brand new genuine GU slave with a Bosch GQ slave because it had a smaller bore. This is sometimes necessary for the NPC Viper clutch.
Well all perfect now and very smooth. Learnt a whole bunch along the way as well.
9th May 2019, 12:49 AM
Good to read that you fixed the problem.
