4th May 2019, 04:13 PM
Idling issue duel fuel TB42e
I'm getting balder by the day. I set the timing on the wagon idling on 750-800 rpm then when I restart it it goes and idles at 1400 rpm or more. I replaced the head gasket but didn't alter anything else. No vacuum leaks, all vacuum hoses on. Its running on gas as for some reason when I switch to petrol it cuts out, no fuel getting there. It wasn't a problem before I pulled the head and all wires appear to be connected. Never had a efi Patrol before so all new to me. Is there an Idle adjustment screw on this motor? I have the gas timed at about 12 degrees BTC as any higher and idle lifts to much. Any help would be much appreciated especially with pictures
Pete
4th May 2019 04:13 PM
5th May 2019, 04:56 PM
