Results 1 to 4 of 4
Thread: rear fake tail light
    Expert jman69's Avatar
    S.A.
    just wondering how to remove the rear brake light from the left side? Is it the three small bolts just inside the removable flap? I need to get to the reverse wire to connect a reverse camera. thanks in advance.
    The master farter
    mudski's Avatar
    461 Post(s)
    Might help if to tell us what vehicle it is. GU's have two mounting bolts on the inside of the rear section of the cab...
    S.A.
    sorry, it's a 1998 gu. oh , and thanks.
    Use a 1/4 drive socket set to remove the 10mm bolts.
    take care easing them out the palm of your hand will help.
    If you have a trailer plug you can access the wires from RRHS
    underneath.
    I mounted a camera on the black Patrol name on the small door
    looks factory IMO
