Results 1 to 8 of 8
Thread: GU series 2 gear shift
    May 2016
    8 Post(s)
    Hi all my gearshift is loose I think !
    I think I think , so what's in the shift ? I am not sure if its a feature .
    its just as not as positive as I think it could be . maybe . not sure what to expect .
    464 Post(s)
    pretty much theres a ball section on the gear stick which sits in a nylon bush. Then in the top of the box the the gearstick sits in the selector. There is also a nylon bush in there. Easier to replace, a bit time consuming though as the centre console needs to come out. Then you remove the circlip holding in the gearstick and the whole lot simply pulls out.
    These two bushes are the only thing that wear out. There is a spring in there that keeps the tension on the stick into the box, this can break, but very rare...
    Tip12345 (23rd April 2019)
    May 2016
    8 Post(s)
    if I change gears a bit quick it gets in knots ! I will take it to bits and have a look thanks
    464 Post(s)
    Quote Originally Posted by Tip12345 View Post
    Not really sure what you mean by that but if I change from 3rd to 4th a little quick in mine whilst accelerating a bit harder than usual I get a grinding like feel through the stick. Which would mean the synchro's are at their end of life.
    May 2016
    8 Post(s)
    my shift is just a bit vague . the truck only has 140.000 km . I will pull the top off it and have a look . I will keep an eye out for another Nissan Patrol and have a feel ! ... Wont that go down well !! Hi can I have A feel of your gear stick !!! wish me luck
  8. The Following User Says Thank You to Tip12345 For This Useful Post:
    threedogs (24th April 2019)
  9. #6
    May 2016
    8 Post(s)
    well I have had A feel of another nissans gear shift !!
    Mine does not centralise a bit like there is a spring broken or something . Any ideas ?
    I did the download the manual thing and cannot get it to work .... anyone go a picture of the gearshift assembly . thanks to all
  10. #7
    464 Post(s)
    Circled in red are the two bushes you get in the kit and the spring which is sold separately, this rarely breaks or loses tension, but it can. Theres nothing to it really. Even the circlip that holds the lot in could have snapped maybe
    Tip12345 (30th April 2019)
  12. #8
    May 2016
    8 Post(s)
    thanks now I know what I will be doing this weekend ! thanks again
