22nd April 2019, 02:22 PM
Warped disc rotors ?
For a while now, I noticed what I'd call a pulsating feel through the brake pedal when coming to a halt. I'm unsure, but I feel like the issue is exacerbated when coming to a halt from higher speed ,e.g. coming off a freeway.
For ages I disregarded it and put it down to bad vibration off the road and the vibration I had from a bad engine mount (which is now replaced).
Over the past week I've sort of felt it worsen after a high country trip. So, I figured I'd pay some attention to it.
I'm super naive with brakes and have refused to tinker with them my self. I had the front on stands today , wheels off & I had a look without taking much off and to me everything spins "ok". The sound of rotors ever so gently rubbing against the pads is even and no noticeable differences round the clock.
This is without taking the calipers or anything else off ( as i don't know how to). I also checked the wheel bearings and all seems good. Even with the wheel on, 12 to 6 o'clock shake had NO movement. Pads are ok, as I had that and fluids replaced a few months ago.
Is there any way I can somehow confirm it is the rotor/s my self or is it off to mechanics for a rotor off to have a proper look ???
PS. If it is the rotors, this could smell like one of those 4.8 upgrades. Possibly. Maybe. I don't know .
22nd April 2019 02:22 PM
22nd April 2019, 02:40 PM
Sounds like rotors to me,depending on the thickness they could do with a skim.
Get an on-site on car disc machine done.
Proud BTrol Owner
The Following User Says Thank You to Yeti's Beast For This Useful Post:
22nd April 2019, 04:29 PM
I've got the same symptoms mate. Only very minor. I assume mine is the rotors.
Far as I'm aware you won't necessarily be able to "see" any defects. Might be able to check them with a dial indicator but I wouldn't bother. Last time I had a set machined it wasn't expensive.. like $20 or something. Try that and troubleshoot if you're still having dramas after.
22nd April 2019, 04:54 PM
@Hodge
When my rotors were suss, I would get a slight pulsating feel in the pedal while solid descending into hard corner on sealed surface up the mnts. My bearings were good / pads were 70% left.
I changed them out with DBA slotted rotor and new pads. Pretty cheap these days. Could have used the old pads but put in shed in case.
Machining is fine, but if rotors have hot spots, which may not necessarily be evident and can cause problem again after machining.
Can check rotors for run out with a dial indicator but the time involved will cost. Depends what suits you and the cost will give you a direction.
May be worth checking wheel bearing end play (nipping up) but most likely be the rotors mate.
The Following User Says Thank You to Bidja For This Useful Post:
22nd April 2019, 04:55 PM
Hardcore
Had exactly the same symptoms. Needed new pads so decided to replace the rotors as well, issue gone and greatly improved stopping.
Be very careful before electing to have the rotors machined on car, have a look a previous post by Cuppa. Pearcey provided some excellent advice on this and he’s speaking from experience.
http://www.nissanpatrol.com.au/forum...Disc-Machining
Jack
The Following 2 Users Say Thank You to jack For This Useful Post:
Cuppa (22nd April 2019), Hodge (22nd April 2019)
22nd April 2019, 06:28 PM
Thanks for the heads up folks! Some good reading in Cuppas thread.
Spoke to one of the blokes from out high country trip, and he brought up a good point which could explain why my issue got worse after that weekend.
One of the track descends we done, was super steep and super long. My 1st gear 4L motor braking just didn't cut it, so I did ride the brakes a fair bit. I completely forgot about this!
Hmmm. Now, to look at new rotors while its all apart or just get it machined. Decisions.
23rd April 2019, 08:09 AM
Hodge
Especially when you are riding the brakes and then hit a puddle or do a river crossing. The cold against the hot metal can warp things. I got my discs machined pre TB upgrade and from memory it cost $70 an end, and he came to me and did it in the driveway. He smoked about 30 ciggies per wheel too. Lol.
Hodge (23rd April 2019), Yeti's Beast (23rd April 2019)
24th April 2019, 02:08 PM
@Hodge also check your wheel bearings , if loose a little
bit will give you that warped brake feeling
24th April 2019, 03:34 PM
Moderator
@Hodge mate the front disks are pretty easy but have a wheel bearing internally. Look at my CV rebuild thread ans ther are great pics from go to getting the disk off. It might be viable to take the opportunity to do a swivel hub rebuild and new wheel bearings while doing the disks IMO.
Check out my Toy -->
Rogue Dung Beetle
24th April 2019, 03:37 PM
Moderator
Have a look at the first page of this thread for the diagram.
http://www.nissanpatrol.com.au/forum...Rebuild-Thread
You could take it all off and unbolt the disk from the hub without touching the bearing carrier if you thought your front end was still OK. But it does have to come 0ff.
Rogue Dung Beetle
