18th April 2019, 09:28 AM
Adventure Kings Throttle Controller ??
Hi All,
Has anybody tried or uses an Adventure Kings Throttle Controller ??
Have a couple of questions regarding the Bluetooth side of it.
1. is the entire unit out of site? (ie. no control panel)
2. do you switch between modes via your phone / device ?
I have a windbooster unit in my other vehicle that I leave on the highest power setting all the time, I have had it on for about 5 years now I think and have had no issues.
The AK unit is only $118 inc postage (but not to my place) which is pretty good if it works
18th April 2019 09:28 AM
18th April 2019, 12:37 PM
Update , answered my own questions after finding a UTube video on it.
Yes it is all hidden and does switch between modes from your phone / device.
Still after any feedback / thoughts if anyone is running one
18th April 2019, 12:46 PM
Daily Lurker
R055IE
Hi All,
Which car is it for mate? A y62? I thought the gu had wire throttle?
18th April 2019, 01:00 PM
rusty_nail
GU use an electronic throttle position sensor Nic. All GQs and the GU TD42 variants use cable.
rusty_nail (18th April 2019)
18th April 2019, 05:25 PM
IMO those throttle controllers are snake oil..
Just press the throttle 10% more with your foot and there you go.
2003 GU SIII Auto Grenade. All the goodies.
The Following User Says Thank You to Softy For This Useful Post:
BigRAWesty (19th April 2019)
19th April 2019, 03:29 PM
Agree just slam your foot against the A pillar bit and rock your foot sideways
try to avoid the Toyota lurch not a good look lol lol
2nd May 2019, 07:01 AM
Hi All,
I bought and fitted the 3 setting blue tooth model last week , I have it set in “sport” mode and the difference is very noticeable , all throttle pedal lag is gone and the power gain is pretty good .
Overall happy so far , no issues hooking it up just plugged in and set via phone app.
The Following User Says Thank You to R055IE For This Useful Post:
2nd May 2019, 10:37 AM
#8
Can help to reduce throttle lag caused from drive by wire set up in stock CRD eng. Used one 2 yrs ago when running stock VNT vac solenoid controlling boost but was removed when I installed manual boost control Dawes / Tillix and needle valve.
Currently trialing a throttle control unit with Tillix and the stock VNT vac solenoid (in lieu of a needle valve). ECU remap, max boost 26psi, H/F stage 3 turbo and getting good results. Helps to to get the larger turbo exhaust wheel to spin up quicker and is very noticeable low down in 4th &5th gear (24psi by 2000rpm). Running it at mid high level range as this is all is needed for my setup.
