9th April 2019, 04:25 PM
Idle problem
Fellas I just finished the head gasket replacement on my GQ TB42e and find my idle is too high at 1100
rpm when warm. I've done all the normal checks made sure the cable was a bit slack with no pedal but still no change. Prior to the headgasket blowing it would idle at 750ish rpm. Any help would be appreciated.
Pete
9th April 2019 04:25 PM
10th April 2019, 08:19 PM
As it was fine before you had it all apart,could be a vacume leak from a hose not being connected
The Following User Says Thank You to Deano2506 For This Useful Post:
11th April 2019, 02:19 PM
Thanks Dean. forgot 1 vac hose All good now.
11th April 2019, 05:20 PM
Good to hear mate,it's a usual,easy to make mistake
13th April 2019, 02:17 PM
3 cheers for @Deano2506 hip hip horay, hip hip horay, hip hip horay
Reckon 90% of problems are either vacuum hoses or earth straps lol lol
The Following 2 Users Say Thank You to threedogs For This Useful Post:
Deano2506 (14th April 2019), PeeBee (13th April 2019)
