Results 1 to 5 of 5
Thread: Idle problem
    Jan 2018
    Pt Augusta SA
    Idle problem
    Fellas I just finished the head gasket replacement on my GQ TB42e and find my idle is too high at 1100
    rpm when warm. I've done all the normal checks made sure the cable was a bit slack with no pedal but still no change. Prior to the headgasket blowing it would idle at 750ish rpm. Any help would be appreciated.
    Pete
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    As it was fine before you had it all apart,could be a vacume leak from a hose not being connected
  4. The Following User Says Thank You to Deano2506 For This Useful Post:
    Pete49 (13th April 2019)
    Jan 2018
    Pt Augusta SA
    Thanks Dean. forgot 1 vac hose All good now.
    Apr 2017
    Hobart,tasmania
    Good to hear mate,it's a usual,easy to make mistake
    3 cheers for @Deano2506 hip hip horay, hip hip horay, hip hip horay
    Reckon 90% of problems are either vacuum hoses or earth straps lol lol
  8. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Deano2506 (14th April 2019), PeeBee (13th April 2019)
