Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Rear door ladders?
    194 Post(s)
    Sure has been a bit of effort John in the design of those ladders, look great and very functional.
  2. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    jff45 (6th April 2019), MB (14th December 2020)
    Jun 2020
    Chaps, I've welded up a small barn door for my Y61 GU Patrol, but now trying to figure out the connections to the door. The frontrunner one has three riv nuts down the bottom and two up top - my reckoning is that the top two go through two layers of door steel (where it's folded double) and three go through what I think is a single layer of panel steel.
    Does anyone have any experience with these fitments being enough for normal use? 100kg person on the ladder carrying stuff?
    I'm not good enough with the welder to do a folded over hook type thing on the top (which I'd prefer of course) - unless anyone has some particularly easy ideas to execute.
  5. #13
    472 Post(s)
    G’day CSN61 Mate!
    If understanding correctly you’ve made a door ladder for your small barn door?
    Rivnuts/Nutserts are strongest in shear lateral weight forces for your application but not so great with outward pull forces in such light panel metal.
    Some beautifully engineered designs above but first things first check your barn doors for cracks looking at their opened edges at approximately the glass line bottom.
    Strengthen that OEM fault first is my nuffy opinion as you’ll probably find the spare wheel bigger door already has a crack from only days out of the factory :-(
    10G (15th December 2020)
  7. #14
    472 Post(s)
    Once watched a Stubborn Legend with a seriously buggered hip load all of his family’s touring lightweight gear up top off a simple 8kg thingo similar to this:
    Think it was smartly/quickly mounted to his steel aftermarket tyre/jerry can rear bar swing arms but also doubled as a a table family cooker station table under their awning, one less table to carry
    These GU’s hit legal GVM very quickly touring unless you have awesome aluminium welding skills like JFF45 Mate
  8. The Following 3 Users Say Thank You to MB For This Useful Post:
    10G (15th December 2020), jff45 (15th December 2020), Winnie (15th December 2020)
  9. #15
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    I think "awesome" is stretching it a bit
    John
  10. The Following User Says Thank You to jff45 For This Useful Post:
    MB (15th December 2020)
  11. #16
    472 Post(s)
    You’re too humble JFF45 Mate!
    Ingenious design pictures above may not reflect to your good self them beaut skills but I’ve thankfully seen over the years even betterer sneaky ‘truly awesome’ pictures you’ve kindly added whilst assisting blokes
  12. The Following User Says Thank You to MB For This Useful Post:
    jff45 (17th December 2020)
