Results 1 to 4 of 4
Thread: Denco turbo kit and td42ti injector pump
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Got them up on ebay with more pictures. Resonable offers considered. Located Northern suburbs of Adelaide
    Denco turbo kit. Was running fine, no issues with it at all. Upgraded to bigger unit. Comes with all the bits I took off. Should bolt straight up to standard setup with 3in exhaust with no mods. On ebay for $500.
    https://rover.ebay.com/rover/0/0/0?m...2F254180950949
    Gu Td42ti injector pump. Came off running with no issues or leaks. 260,000km on the odo.
    Ebay for $500 as well
    https://rover.ebay.com/rover/0/0/0?m...2F254180958286
    581 Post(s)
    Does anyone if that pump would be ok on the td42 Gq black na?
    Because of the TI pump and the electric thinggys???
    The work Gq is desperate for both turbo and pump?
    Jan 2017
    South Australia
    11 Post(s)
    Replied via DM mate but for the purpose of discussion...
    From what I understand they default to full advance. So the pump could still be set to a fixed timing point. I just don't know if you'd still time it the same way.
    Jan 2017
    South Australia
    11 Post(s)
    Both gone today.
    Thanks @AB thread can be locked/deleted or whatever magic you work with it.
  6. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    AB (12th April 2019)
