Results 1 to 10 of 10
Thread: Starter motor removal on a GQ 4.2td
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Mr Nissan not only stuck it in a shit spot he covered it in oil filters , anyone have an easy way to remove the starter motor on GQ 4.2 diesel motor .
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Came off pretty easy from underneath? Mines a GU and I had it on a hoist but I wouldn't think it would be too different to the gq/laying on your back.
    Had to take mine off to do the clutch and I don't remeber it being that difficult. Just degrease and wash it all first.
  4. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    GQtdauto (23rd March 2019)
    472 Post(s)
    Thankfully have never needed to undo on any owned Patrols Rob mate. Might be time for an early oil filter change to have a better open crack at it until a GQ guru comes along here mate!
    EDIT: @AB is your man here Rob mate. Completely forgot when we unfortunately popped his GQ donk, pretty sure the top team here doubled socket extensions, at least for topside bolt IIRC mate.
  7. #4
    It is a pain in the ass to reach but shouldn't be too hard. Can't remember exactly how I did mine but think I just used spanners. There aren't any magic tricks though if that's what you are hoping for.
  8. The Following User Says Thank You to Winnie For This Useful Post:
  9. #5
    192 Post(s)
    Yeah top bolt and wiring from top and other two bolts from underneath then jiggle out through the bottom. Bottom bolts bit of a pain cos you don't get much room to spin the spanner, ratchet ringgy might help.
  10. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    GQtdauto (23rd March 2019), MB (23rd March 2019)
  11. #6
    472 Post(s)
    Yeah but you’re a cheata @Rossco mate, entire shell off rebuild Legend doesn’t count here :-)
  12. The Following 3 Users Say Thank You to MB For This Useful Post:
    GQtdauto (23rd March 2019), MudRunnerTD (24th March 2019), Rossco (23rd March 2019)
  13. #7
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I thought it would be a snap from underneath but I can't even get to one bolt on mine , so will remove the oil filters because it needs an oil change anyway and try from up top .
    Thanks for your info guys will track down the spare extensions just in case .
  14. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    0-TJ-0 (23rd March 2019), MB (23rd March 2019)
  15. #8
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Thanks again everyone I've managed to remove it after pissing the filters off , could not find my filter strap but lucky for me one was about three quarters of a turn from being tight and once removed the other one had better access and was also loose .
    I've got no idea why the loose filter wasn't leaking everywhere but looks like it might have just started to weep a bit of oil .
  16. The Following User Says Thank You to GQtdauto For This Useful Post:
    0-TJ-0 (24th March 2019)
  17. #9
    Jan 2017
    South Australia
    11 Post(s)
    After a few issues with stuck filters in my younger days I've only ever done mine up hand tight, just so they bind and don't spin loose or leak. No tighter. Never had a problem and I've never had to use a filter strap since.
  18. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    GQtdauto (24th March 2019)
  19. #10
    175 Post(s)
    Same here. Never had an issue. First time I ever serviced my TD42 my self filters were so loose, I was gobsmacked how they didn't leak.
    They don't need to be tight. The rubber seals to their jobs. As long as you oil up those seals while spinning them on so as not to distort them, the seal will hold with minimal tightness.
  20. The Following User Says Thank You to Hodge For This Useful Post:
