Results 1 to 5 of 5
Thread: Where to put my vacuum line for my compansated pump ?
    Expert First Pooy's Avatar
    Mar 2018
    I am installing my 12 mm compensated Ip tomorrow and the old one didn't have one, so where do you get your vacuum from ?
    22 Post(s)
    The compensator needs boost pressure not vacuum.
    If you are referring to the A/C Idle up, that comes from a vac operated switch on the firewall, if you dont have that, you'll need one or block the port off
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    AB (22nd March 2019)
    Mar 2018
    Ahh sorry I hadn't really looked at it yet I assumed it was vaccum,so where from then ? Frome.the wast gste feed ?,I have my boost gauge coming out if my intake but will that affect my boost reading?
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Depending on your setup you'd be better off drill and tap a new hole in the intake manifold imo. Too many t's coming from the one spot can end up causing you drama's if something gives up the ghost/leaks.
    Leave the waste-gate feed alone, if you really want to tee it off i'd use the boost gauge line assuming they're separate.
    581 Post(s)
    I used my waste gate feed but do agree with old mate above with the boost feed if its close to inlet, etc.
