Results 1 to 4 of 4
Thread: Add On to my home made racks
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, add more rails to my rack system, So i can put my cheapo ebay "MaxTraks" on my roof . please note it's not easy drilling S.S. bolts , wd40 doesn't help. each hole cost one drill bit at $9 dollars lol done now
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  2. The Following 3 Users Say Thank You to altech For This Useful Post:
    MB (17th March 2019), MudRunnerTD (17th March 2019), rusty_nail (17th March 2019)
    Key to drilling stainless is very low speed, too fast or using WD40
    will just melt drill bits. imho
    altech (18th March 2019)
  6. #3
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    And gotta keep it cool. Do not get the SS hot or you will just bugger up your drill bits. Use cutting oil or paste too.
  7. The Following User Says Thank You to Brissieboy For This Useful Post:
  8. #4
    Nov 2011
    Rupanyup, 3388, VIC
    that is was I thinking, buy a high speed drill. then you must drill at high speed. Thanks for the advise cheers Alex
  9. The Following User Says Thank You to altech For This Useful Post:
    threedogs (19th March 2019)
