Results 1 to 9 of 9
Thread: GU Clutch noise
    Advanced Mentok's Avatar
    Apr 2011
    Tindal, NT
    GU Clutch noise
    G'day everyone,
    I have an issue with what I think is my clutch when towing the camper. When up shifting gears there is a whirring noise that comes from the gearbox when the clutch is fully depressed. Its not the shifting action thats making the noise. Any suggestions?? Thrust bearing?
    2015 GU ST Patrol, ZD30, Manual, 3" AmadaXtreme Explorer II Shocks with Dobinson Flexi coils, Warn XD9000 Winch, 33" BFG Mud Terrains, IPF Spotties, ORS Drawers, 3" DEA exhaust, catch can, Tillex valve.
    472 Post(s)
    From what you describe above Mentok mate it does sound like Thrust bearing to my nuffy understanding.
    Run outside to your carport now and fire it up in neutral then see if it sounds the same every time you depress and release the clutch even when out of gear.
  4. The Following User Says Thank You to MB For This Useful Post:
    Mentok (17th March 2019)
  5. #3
    109 Post(s)
    My TD42T rattles big time at idle in neutral. Depress the clutch the rattle disappears. Release the clutch it's rattle time again. Have been told this is a symptom of worn thrust bearing. Sounds opposite way around to Mentok's 3.0L clutch whirring noise?
  6. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    MB (16th March 2019), Mentok (17th March 2019)
  7. #4
    Apr 2011
    Tindal, NT
    MB thats my thoughts too but the noise doesn't happen at idle only when driving with the camper on. My thoughts are that the thrust bearing is slowing down slightly during shifts and has some damage on it to make the noise.
  8. The Following User Says Thank You to Mentok For This Useful Post:
    MB (17th March 2019)
  9. #5
    472 Post(s)
    GU Clutch noise
    Plasnart mate reminded on last post that one of our old work TD42T’s still does the same exactly. Has been doing it for 2-3years now so not sure what’s all our answers now sorry mate!
    EDIT: A 5th gear old version box issue maybe or all gears Mentok mate?
  11. #6
    472 Post(s)
    @Mentok mate, are you 100% sure the noise aint coming from the Patrols arse end?
    Just thinking you’re towing in 2WD highway hauling (unknown weight to us) maybe she’s dry and worn back there?
  12. The Following User Says Thank You to MB For This Useful Post:
  13. #7
    Apr 2011
    Tindal, NT
    Doesn't sound like the noise is coming from the rear end and not sure what would make that type of noise in the rear end with the clutch in. The camper weighs approx 1500kgs.
  14. The Following User Says Thank You to Mentok For This Useful Post:
  15. #8
    472 Post(s)
    Fair call mate
    Could be time to drop the box out anyways for a quick gander in the bell housing, keen to learn here too good man
  16. #9
    Apr 2011
    Tindal, NT
    That's the plan. Got a small trip coming up real soon (Easter/ANZAC break) and then a Gibb trip in June. Don't want any dramas while i'm away. Cheers for the help.
  17. The Following User Says Thank You to Mentok For This Useful Post:
