17th March 2019, 02:59 PM
#11
threedogs
Ran the wires up the D pillar terminating in a 50 amp anderson plug,
easy if I need to replace the light bar,, works a treat
Would you happen to have a photo of where exactly you mounted the Anderson plug?
Sent from my CPH1701 using Tapatalk
17th March 2019 02:59 PM
18th March 2019, 01:43 PM
#12
Rixter
I have a chinese ARB copy roof rack and just bolted
the Anderson plug to the roofrack mounting plate
18th March 2019, 02:16 PM
#13
18th March 2019, 03:40 PM
#14
Patrol Guru
mudski
I did mine like this but didn't even bother cutting the notch out. Just clamped the seal over the top. Always intended on finding a better way but I've never had an issue in the 4 or so years it's been like that.
The Following User Says Thank You to 0-TJ-0 For This Useful Post:
