Results 1 to 10 of 14
Thread: Spot Light Wiring to Front of Roof Rack
    Feb 2019
    Victoria
    Question Spot Light Wiring to Front of Roof Rack
    How have people run their wiring from inside their Patrols out to the front of their roof rack mounted Spotlights?
    If you have any photo's how & where you've done it that would be fantastic.
    Thanks in Advance for your advice.
    194 Post(s)
    Do you have a snorkle? Run the cables up the back and bridge them across to the lay in the roof gutter then up the leg of the light bracket or roof bar/rack. Or as i did, drill a hole in the roof and grommet it. If it ever needs to be removed, stick a blank grommet in the hole - depends on colour of vehicle as to how obvious, but mine is dark charcoal so do not stick out. Remember to do a good job on the rust treatment of the drilled hole as well. No pics, away from home at the moment.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    Rixter (15th March 2019)
    581 Post(s)
    Not suggesting to do this as I don’t run roof lights but have seen people run them down inside snorkel and into bonnet or run down snorkel under side hidden to avoid cutting into roof of body.
  6. The Following User Says Thank You to AB For This Useful Post:
  7. #4
    Feb 2019
    Victoria
    Thanks for the replies guys.....I was wondering if anyone has run the cable up & out of a door pillar (between front and back doors) and then around to the front of roof rack? Ive seen it done years ago on a police car to run the flashing lights on the roof.
  8. #5
    Quote Originally Posted by Rixter View Post
    Yeah i ran my roof lights out the back door to the B pillar for years on my GQ. Worked great. I have recently drilled a hole in the roof because ita forever and im ok with that.
  9. #6
    472 Post(s)
    Tis a bit Agricultural Rixter mate and should seriously have more McZippy’s used but does keep the voltage length closer to the sauces :-)
  10. The Following 3 Users Say Thank You to MB For This Useful Post:
    AB (15th March 2019), GQtdauto (16th March 2019), MudRunnerTD (15th March 2019)
  11. #7
    My GUIV is the same as this
    MB (15th March 2019)
  13. #8
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    I was wondering if anyone has run the cable up & out of a door pillar.
    I have run wiring up the inside of the passenger side pillar and mounted 2 small 30amp Anderson connector pairs on a plate that mounts behind the plastic using the bolt that holds the rear passenger seat overhead hand grip (trying not to put holes anywhere that are not absolutely necessary and want the wiring totally concealed). The mounting plate also mounts one end of a curtain bar I use to provide privacy when I camp in the back.
    It was a bit of work getting the wiring in as I ended up having to pull out the front passenger seat so I could get the plastic covers off and the wiring safely tucked away so it didn't interfere with the seat belt in any way.
    My connections are not permanent, hence the plug/socket concept. I just run the cable out above the door - there is plenty of space there so no damage to the cable and I don't get any water ingress.sockets.JPG[edit] Not sure why, but the pic has been rotated - the left side should be up.
  14. The Following User Says Thank You to Brissieboy For This Useful Post:
  15. #9
    472 Post(s)
    Penetrations on our shells are scary for longevity of our beloved beasts all of us!
    Go industrial wherever possible @matfew thanks old mate and or at least nuclear prime our tekkies with wet wubber for years to come
  16. #10
    Ran the wires up the D pillar terminating in a 50 amp anderson plug,
    easy if I need to replace the light bar,, works a treat
  17. The Following User Says Thank You to threedogs For This Useful Post:
    Rixter (17th March 2019)
