A whole bunch of people on here have done them slightly differently. Have a bit of a search through and you should find some good info.
I would, and am going to avoid using anything with the standard filter element. If you're going to spend the time and money look at upgrading to an ls1 filter or larger pod style filters. If you stick with standard you'll only get limited benefits.
None of those airbox's are an upgrade for a 42. Especially a 'built' one as described in the Demon Pro Parts link.
This kind of crap is really starting to burn my piss big time. High dollar junk items. There is more than enough free info out there as to why these are crap .The aftermarket is littered with copycat mediocrity and a lack of engineered, high quality products.
That Piece of crap DPP airbox, with its ability to flow 290 cfm or, literally half of the amount of air an N/A TD42 can consume (let alone a 'Built' one) is more than enough proof that it a waste of money.
Recently fitted 4" thru airbox, made by self employed boiler maker, contact thru ZD Warrior FB (Ben Lipscombe). Makes them for TD42 (330mm long) and 300 long for CRD. I have a CRD and got him to make one same as TD42 (330mm), takes 9" K&N pod filter. Good 50-60mm clearance to base of pod filter. Does inlet / outlet size to suit (Recommend 4" thru)
Cost was $365(includes postage) w/o filter, Have 4" snorkel, Procharge stage 3 h/f turbo, Jonny Tig cooler - 136 rwkw/512 N-m. Well made and draws well (similar build to Fatz airbox).
