Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Tablet and phone mounts
    Patrol Guru TimE's Avatar
    Canberra
    3 Post(s)
    I used some cheaper stuff prior to the Ram gear. Don't waste your time & money, the Ram stuff is top quality.
    Yep, I've pounded over a squillion corrugations and the RAM mount holds firm, well worth the extra $s.
    Patrol Guru 10G's Avatar
    May 2016
    lower west victoria
    14 Post(s)
    Here you go.
    I've screwed one of the balls onto the dash. Built a backing plate out of 1.2mm gal sheet I think it is. The arm goes from the ball on the dash to a ball attached to the backing plate. The Ram mount screws to the backing plate and into the pen holder part of the dash as you can see.
    It is VERY rigid, corrugations.vibrations barely bother it.
    .. speak up, my hearing isn't what it used to be. It used to be my vision and I can't see what you're saying ..
  4. The Following 2 Users Say Thank You to 10G For This Useful Post:
    0-TJ-0 (8th March 2019), Softy (9th March 2019)
  5. #13
    168 Post(s)
    This is what I was looking for before
    http://www.nissanpatrol.com.au/forum...tion-and-Comms
    This is basically the set up I had but mounted differently as mine was a GQ.... Very secure
    I have done this exactly in my GUIV. Works Awesome. Full size ipad. I added a double USB to allow to charge the ipad while touring.
  6. #14
    Expert 0-TJ-0's Avatar
    Jan 2017
    South Australia
    Awsome, thanks fellas. They have a bunch of options so I'll be able to find something to suit. Never even looked at the Ram stuff before.
  7. #15
    95 Post(s)
    Not cheap but they're good
  8. #16
    168 Post(s)
    Best on the market. Pay for quality. RAM is great
  9. #17
    Feb 2019
    Yep agreed RAM are the way to go. I just use a windscreen suction style with the x-grip for my iPhone. Works great. Nice and solid C360D876-8769-45A5-91C6-21708DEA1C21.jpeg
  10. The Following User Says Thank You to ChadGU For This Useful Post:
    0-TJ-0 (10th March 2019)
