Results 11 to 20 of 23
Thread: Tablet and phone mounts
    Patrol Guru TimE's Avatar
    Canberra
    I used some cheaper stuff prior to the Ram gear. Don't waste your time & money, the Ram stuff is top quality.
    Yep, I've pounded over a squillion corrugations and the RAM mount holds firm, well worth the extra $s.
    May 2016
    lower west victoria
    30 Post(s)
    Here you go.
    I've screwed one of the balls onto the dash. Built a backing plate out of 1.2mm gal sheet I think it is. The arm goes from the ball on the dash to a ball attached to the backing plate. The Ram mount screws to the backing plate and into the pen holder part of the dash as you can see.
    It is VERY rigid, corrugations.vibrations barely bother it.
  4. The Following 2 Users Say Thank You to 10G For This Useful Post:
    0-TJ-0 (8th March 2019), Softy (9th March 2019)
  5. #13
    This is what I was looking for before
    http://www.nissanpatrol.com.au/forum...tion-and-Comms
    This is basically the set up I had but mounted differently as mine was a GQ.... Very secure
    I have done this exactly in my GUIV. Works Awesome. Full size ipad. I added a double USB to allow to charge the ipad while touring.
  6. #14
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Awsome, thanks fellas. They have a bunch of options so I'll be able to find something to suit. Never even looked at the Ram stuff before.
  7. #15
    Not cheap but they're good
  8. #16
    Best on the market. Pay for quality. RAM is great
  9. #17
    Feb 2019
    Yep agreed RAM are the way to go. I just use a windscreen suction style with the x-grip for my iPhone. Works great. Nice and solid C360D876-8769-45A5-91C6-21708DEA1C21.jpeg
  10. The Following User Says Thank You to ChadGU For This Useful Post:
    0-TJ-0 (10th March 2019)
  11. #18
    194 Post(s)
    Guys, looking for a suitable, robust RAM mount or Ram style mount for an IPAD mini into a GQ - @Winnie, @MudRunnerTD, @Rossco, @ AB, what have you got, pics pls. As you would be aware I am realestate poor, but the Hema is a bit too small now for my aging eyes.
  12. #19
    I suggest not using a windscreen mount. I have for years but it does fall off occasionally and is a pain in the ass... I need to buy some new bits for mine cos I am just gonna screw it through the dash.
  13. The Following User Says Thank You to Winnie For This Useful Post:
    PeeBee (15th June 2019)
  14. #20
    192 Post(s)
    Hey Phil mine is a Dick Smith cheapie but made my own bracket from the swivel down. Originally had it screwed into the dash with self tappers but they came loose after pounding through outback corrugations, have got it bolted through the dash now fiddly job but solid as. Yeah wouldn't recommend suction cap unless you enjoy it randomly falling off. .
  15. The Following User Says Thank You to Rossco For This Useful Post:
    PeeBee (16th June 2019)
