Results 1 to 5 of 5
Thread: Fuel Gauge moved lower than reading...any ideas???????
    Advanced maverick1's Avatar
    May 2011
    Nth QLD
    Hey everyone,
    I have a mav 88 and a while ago the fuel gauge started dropping below empty. So when it is full it reads 3/4 full and when it is empty it is another 1/4 below empty. Does anyone have any suggestions? Is it the gauge? sender?
    Thanks.
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I assume its a petrol.....and I would say the sender, mine is the same...... have adjusted it many times, but have now given up and just go on how many K's i have done. If you do take the sender out, make sure you buy an o'ring for it before hand, from my experience the old one never goes back on.
    Todd
  4. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    maverick1 (3rd June 2011)
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    took mine to the auto leccie suffering the same symptoms - it was a faulty component in the dash, a resistor I think, in my case.
    Since I had uncovered the access to the sender (remove load area carpet and sound deadener underlay stuff, and remove the cover in the centre) he took the sender out, however it tested OK.
    Havn't run out of petrol since!!
  6. The Following User Says Thank You to Silver For This Useful Post:
  7. #4
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I would say your problem is with the gauge.
    To test it you will need a variable resistor with a range of at least 4-90 ohms and an ohmmeter, or at least an ohmmeter.
    If you have an ohmmeter what you can do is fill the tank with fuel, disconnect the connector at the fuel tank and measure the resistance of the sender (without removing it from the tank).
    With a full tank you should get a reading of between 4.3 and 5.7 ohms.
    If you get this reading then the problem is with your fuel gauge.
    You can either get a second hand instrument cluster or remove your instrument cluster and have it repaired.
    If you get a reading of something like 20-25 ohms (with a full tank of fuel) then I would say the problem is with your sender.
    Quote Originally Posted by Silver View Post
    It sounds like the resistance value of the gauge has changed, this is why I think they changed the resistor, not because it was faulty but to compensate for the changed resistance value of the gauge.
    Hope this helps.
  8. The Following User Says Thank You to Yendor For This Useful Post:
  9. #5
    May 2011
    Nth QLD
    Thanks for all the helpful advice.... will check out all the suggestions.
