Results 1 to 2 of 2
Thread: Water pump cavitation
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Replaced the water pump today and on removing the old pump got quite a shock.
    On the motor
    Old pump
    I just cleaned up the face of the block and put the new pump on. I believe it's caused by low coolant level. Hunting down the reason now.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  2. The Following User Says Thank You to Chubba For This Useful Post:
    AB (11th March 2019)
    194 Post(s)
    Air is highly erosive, and is also an insulator, and you are getting poor kgs of water/rev as part of it is air. Air increases frictional flow within a piping system, hence why so much attention is given to 'burping' the coolant system. Air is compressible, so you can see how ineffective a pump will be if it is half full of liquid and half full of air compared with 100% full of water. Pumps are flow rated at 100% full, not partially full of air. This is minor damage compared to some pumps I have removed from service in poorly designed pumping circuits.
    MudRunnerTD (12th March 2019)
