Results 11 to 20 of 21
Thread: Bunnings flares on a GQ
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yep ET that's pretty much the way I'm doing it just have to get my hands on a heat gun for the final pretty up .
    Have found the original screws with a washer are brilliant and if I slot out the edging I can manipulate it for a better easier fit ,have left the test piece a bit longer than required both ends .
    Once in place and I'm happy ,then to fit a mudflap that's functional but won't get torn off first ding it gets .
    Yeah, I recall I used stainless penny washers but can't for the life of me remember where I put a couple of Teks (trailing or leading)... been too long ago now since my last GQ for my feeble alcohol addled brain :-)
  4. #13
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Cheers ET , I've used cad coated washers using original screws but will have to put a few teks in just to firm it up but so far my only stuff up has been not to start in the middle ,I'll take a few pics when I'm happy but slowly getting there .
  5. #14
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Both rears done and apart from a bit of a tweak here and there thought it wasn't overly bad till I looked at it from the back , mudflaps dont cover enough tyre grrrrrrrr.
  6. #15
    581 Post(s)
    Looks good mate it’s not too bad on the overhang wouldn’t stress too much.
  7. The Following User Says Thank You to AB For This Useful Post:
    GQtdauto (1st March 2019)
  8. #16
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Thanks AB , might just leave it till it gets a workout and see what fails .
  9. #17
    194 Post(s)
    What size tyres are you running?
  10. #18
    Dec 2016
    Northeast Victoria
    41 Post(s)
    33" x 12.5" , I do have a two inch lift but noticed yesterday she's sagging on the passenger side rear and the shocker looks like it's leaking so might get the spring looked at as well .
  11. The Following User Says Thank You to GQtdauto For This Useful Post:
    PeeBee (2nd March 2019)
  12. #19
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Those tyres came with good glue mate.....
    Your flare /
    flap fix will do the job.
  13. The Following User Says Thank You to Bidja For This Useful Post:
  14. #20
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Your flare /
    That Cooper was a gift I just wanted to check the fit , it will do as an extra spare maybe but I would run Hankook before I run Coopers .
    My BFG's were run down and should have been replaced before my last trip , ruined two of them so had to buy two new ones in Katherine but alas the idiot told me they don't make BFG's in 33"x 12.5" even though I had them on the GQ .
    So I dragged him out to look and decided to go elsewhere , ended up with maxxis razr mt .
  15. The Following User Says Thank You to GQtdauto For This Useful Post:
    Bidja (2nd March 2019)
