Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: What's the noise?
    Patrol Guru Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    9 Post(s)
    As per edit note
    For the noise, when it is happening at idle, open the needle valve gradually and does it stop?
    Last edited by Bidja; 15th February 2019 at 07:58 PM. Reason: Deleted first para referred to your boost thread so put it there
  2. The Following User Says Thank You to Bidja For This Useful Post:
    10G (15th February 2019)
    Patrol Guru 10G's Avatar
    May 2016
    lower west victoria
    14 Post(s)
    If CRD check that the VNT solenoid is still plugged in. CRD require it to be plugged in when Dawes/needle installed even though VNT solenoid is bypassed(vac).
    Also check vac lines as you said and at idle have a look and see if the actuator rod is in the up most position (lever hitting stop). Check to see if the actuator rod lock nut has not come loose an allowed the actuator rod length to increase. If too long eng will become very laggy and exhaust will get more of a throaty sound and higher EGTs. The witness line up marks on the the adjuster thumb wheel to actuator rod will indicate any movement. Best leave it alone if looks like it has not moved.
    Thanks Bidja, I'll check all that out over the weekend. Much appreciated.
    .. speak up, my hearing isn't what it used to be. It used to be my vision and I can't see what you're saying ..
  5. The Following User Says Thank You to 10G For This Useful Post:
    Bidja (15th February 2019)
  6. #13
    Jan 2018
    Is it manual? If its manual then thats the standard gearbox chatter. Sounds like rattle or pinging .
  7. #14
    Mar 2019
    Got the solution for the noise.
  8. #15
    May 2016
    lower west victoria
    14 Post(s)
    Seems this is normal. It was enhanced by the vacuum leak that I had. Once I fixed the leak, the rattle almost went away.
