Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Provent oil drain
    Nov 2018
    Cool
    I went a slightly longer route... I ran the tube along the LH chassis rail and when it hit the radiator mount panel curled it down and towards the plastic wind deflector under the radiator shroud. The hose is on a slight downwards run all the way and can collect a goodly amount of oil with no chance of the truck sucking it back if you forget to drain it for a while. I just cable tie it behind the end of the plastic so it cant be ripped out.. One last thing for engine safety is I silver soldered the end of a standard airline fitting (same thread) and wound it in as a bung with some sealer tape. There are two benefits here, 1. cant suck in fresh air or water if you forget the close the spigot (it's a sealed surface), 2. protects the ball cock from dirt and crap .... when i drain it, i just cut the cable tie, drop the hose down and take out the bung and drain, once drained, return the bung and re cable tie....
    Feb 2012
    When I installed the Provent many years ago, I fitted a check valve to the drain and tee'd it into the turbo oil return line to the sump.
    I've never had any condensation in the Provent....just oil, nothing else.
    Set and forget, and I've never had any reason to think I should have done otherwise.
  4. #13
    461 Post(s)
    Quote Originally Posted by geoffayres View Post
    You still floating around mate... How are things? You obviously still have your Patrol.
  5. #14
    Feb 2012
    Hi mate. Yep, I still pop in from time to time. Things are OK thanks, just too busy with work and home stuff to get away as much as I'd like.
    You bet I've still got the Patrol. It's used for holidays or towing duties only these days. I'll have had it 20 years next Jan, and have no plans to change. I don't see anything that else excites me enough....
    How's it all going for you?
  6. #15
    461 Post(s)
    Going pretty good for me. Life is getting busier and busier, due to buying a renovators delight a couple of years ago. So my Patrol just sits there unfortunately.
    geoffayres (4th March 2019)
