Results 1 to 8 of 8
Thread: Electrical issues
    Feb 2019
    Electrical issues
    Hi, my 88 safari has suddenly had the speedo, fuel, temp and oil pressure guages stop working. The tacho and volt meter are working fine? Can anybody suggest where I could start looking.
    Advanced 0-TJ-0's Avatar
    Jan 2017
    South Australia
    I've always found when mutliple things start playing up/not working checking all your earths is the best place to start.
    366 Post(s)
    Check the fuses on the drivers kick panel mate.
    Feb 2019
    Thanks, i checked the fuses before posting, but there must have been a connection issue, as I cleaned each fuse and crced them and it's all go again. Thanks for the advise. Can anyone suggest what the following is for? F7DF4BDF-431B-44D4-A659-291A240D1891.jpeg
    It was inside the passengers kick panel. Thanks
  6. The Following User Says Thank You to Nigelc For This Useful Post:
    0-TJ-0 (9th February 2019)
    84 Post(s)
    Grab a pkt of fuses that suit your patrol maybe a squirt
    of CRC on the fuse may stop corrosion on your fuse
    panel.
    well done finding the problem
    Nov 2012
    Victoria
    looks like something for the stereo unit,looks like it has clarion written on it
  9. #7
    92 Post(s)
    Quote Originally Posted by Nigelc View Post
    In a an Auto TB42e GQ, there's usually an ECU in the passenger kick panel.... But that photo looks like an amp
  10. #8
    Sep 2015
    Perth
    It's one of these.
    A Clarion EP-693H. An original Nissan fitted 24v to 12 voltage converter.
    Apart from that, I couldn't find anything else but it looks like a prime candidate for your gauge problems.
    Jonesy
    Ex Telstra - 2004, TD42Ti DX ute -with Roscos pod. 3900kg WCS GVM upgrade, UFI TD05-16G Turbo, Taipan 3inch exhaust and dump, blocked EGR.
    Front E-locker, 2 x Stratos LTSS seats, Inawise TPMS-203 and 9 monitored wheels.
  11. The Following User Says Thank You to gjones For This Useful Post:
    Clunk (12th February 2019)
