Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: td42t intercooler kit for factory non intercooled
    Advanced
    Jul 2015
    Victoria
    I've seen some kits around but they're pretty pricey at $1500+ does anyone know of any other kits that are cheaper?
    581 Post(s)
    Are you going front mount or top mount?
    Can get away with running a front mount pretty cheap using ebay and working out the piping yourself.
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I know a guy with all the bits for a factory top mount going real cheap..
  5. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    AB (5th February 2019)
  6. #4
    Advanced
    Jul 2015
    Victoria
    Top mount, do you know if someones put a write up on the forums for it? There's a hardline that goes to the intake tube right on top of the engine that I have no idea what it's for, little stuff like that I'm not quite sure of would be great to know. I noticed that the mounting section ontop of the inlet manifold where the 90 degree bend is on factory non intercooled is just 4 bolts and nothing else, where as the 03+ factory intercooled ones have 3 holes that I assume are for some kind of vacuum lines.
  7. #5
    Jan 2017
    South Australia
    11 Post(s)
    Not sure what you're talking about? Pictures would help. I think you're talking about the vacuum lines that control everything for the egr system. You don't *need* any of that and the engine will be better off without it. If yours doesn't have it as standard, no issues.
    You don't need anything special when fitting an intercooler. You just need to decide if you want top mount/front mount/water to air... if you want an easy to fit kit or buy the bits and do it all yourself.
  8. #6
    581 Post(s)
    Yep as above mate throw up any pics and we can help.
  9. #7
    May 2016
    8 Post(s)
    I have just removed a top mount what do you want ?
  10. #8
    Advanced
    Jul 2015
    Victoria
    This is the line I was talking about.
    Also this is the inlet flange I was talking about, this is the one for 99-03
    This is the one for 03 onwards
  11. #9
    The master farter
    mudski's Avatar
    462 Post(s)
    Quote Originally Posted by Viiper View Post
    That Line will probably go down to the injector pump. its for boost compensator, I think. when you run a boost controller this line Tee's intot he controller. As for the other pic, those would be mounting points for vac lines for an EGR system, which you dont have.
  12. The Following User Says Thank You to mudski For This Useful Post:
    0-TJ-0 (7th February 2019)
  13. #10
    Advanced
    Jul 2015
    ORANGE NSW
    I got a standard intercooler off a 2004 4.2 you can have cheep
