Results 1 to 5 of 5
Thread: Diesel smart 20psi actuator.
    Patrol Guru Coldcomfort's Avatar
    Sep 2012
    Yea, Victoria
    2 Post(s)
    Hi all, I h@ve just ordered one of the above. Has anyone had experience on a 2012 CRD?
    Be the person that your dog thinks you are!!
    175 Post(s)
    So in a nutshell, this actuator mimics what the needle and dawes valves do by getting rid of vacuum control and simply uses boost as a reference.
    I had a "similar" thing fitted to my CRD by means of a external wastegate and completely removing vacuum control and getting rid of needle and dawes valves, and it actually worked well.
  4. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Coldcomfort (24th January 2019), Yeti's Beast (29th January 2019)
  5. #3
    Sep 2012
    Yea, Victoria
    2 Post(s)
    It’s in and running. Seems ok so far. Will get onto the open road and see how it is at 110Kph tomorrow. It’s beer o’clock now.
  6. The Following User Says Thank You to Coldcomfort For This Useful Post:
    Hodge (5th February 2019)
  7. #4
    Sep 2012
    Yea, Victoria
    2 Post(s)
    Boost comes on much sooner. Better mid range torque. A good result I think.
  8. #5
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Have one with spring set at 23psi sitting on shelf in shed. Used when first fitted h/f turbo and found from the veins being closed at start of spool up, boost came on early, especially low down and lug well. Removed it as I prefer to be able to slow spool rate (be less aggressive) in the bush when going gets rough. With needle valve it is easy to slow spool for better control when needed. Have JT cooler fitted now and propose to try it again for comparison against Tillix/needle (back to back) soon.
    Have just fitted 4" Air box and snorkel and after I get a better appreciation of performance with manual boost control will give positive pressure actuator (waste gate) a go again. Preliminary drive with upgrade to 4" induction with Tillix/needle is providing good results.
