24th January 2019, 05:57 PM
Diesel smart 20psi actuator.
Hi all, I h@ve just ordered one of the above. Has anyone had experience on a 2012 CRD?
24th January 2019 05:57 PM
24th January 2019, 06:11 PM
So in a nutshell, this actuator mimics what the needle and dawes valves do by getting rid of vacuum control and simply uses boost as a reference.
I had a "similar" thing fitted to my CRD by means of a external wastegate and completely removing vacuum control and getting rid of needle and dawes valves, and it actually worked well.
The Following 2 Users Say Thank You to Hodge For This Useful Post:
Coldcomfort (24th January 2019), Yeti's Beast (29th January 2019)
5th February 2019, 05:37 PM
It’s in and running. Seems ok so far. Will get onto the open road and see how it is at 110Kph tomorrow. It’s beer o’clock now.
The Following User Says Thank You to Coldcomfort For This Useful Post:
Hodge (5th February 2019)
6th February 2019, 03:49 PM
Boost comes on much sooner. Better mid range torque. A good result I think.
7th February 2019, 03:00 AM
Have one with spring set at 23psi sitting on shelf in shed. Used when first fitted h/f turbo and found from the veins being closed at start of spool up, boost came on early, especially low down and lug well. Removed it as I prefer to be able to slow spool rate (be less aggressive) in the bush when going gets rough. With needle valve it is easy to slow spool for better control when needed. Have JT cooler fitted now and propose to try it again for comparison against Tillix/needle (back to back) soon.
Have just fitted 4" Air box and snorkel and after I get a better appreciation of performance with manual boost control will give positive pressure actuator (waste gate) a go again. Preliminary drive with upgrade to 4" induction with Tillix/needle is providing good results.
