Technical Body Repair GU Patrol Y61 Oct 1997 to Sep 2001
Hi,
Attached is a handy pdf for the GU Nissan Patrol Oct 1997 to Sep 2001 for members needing to do body repairs, general service etc.
It is a 16 page pdf covering the following:
Body Tech Vehicle Body Repair Information prepared by VACC Technical Services
GU Nissan Y61 Patrol Oct 1997 to Sep 2001 General Service
Recommended Fluids & Capacities Wheel Alignment Specifications
Camber, Caster, Toe-in, Steering Axis Inclination, Toe-out on turns Wheelbase, Track & Overall Dimensions Headlight Aiming Lifting Points Identification & Label Location
Id, Compliance, Build, Fan, VIN, Eng Number, Tyres Placard ABS
Locations, Disable / Enable Procedures Electrical Components Location Plastic Parts Body Construction
Body Components, Under Body Components Body Dimensions
Under Body Dimensions and Co-ordinates
The Following 6 Users Say Thank You to glddt For This Useful Post:
Cremulator (17th January 2019), GQtdauto (18th January 2019), Hodge (17th January 2019), MB (17th January 2019), MudRunnerTD (17th January 2019), Woof (17th January 2019)
Thats a Great contribution mate. any chance you have access to the same thing in a GQ?? The last few pages are very helpful for sure. Thanks Mate.
Hey MudRunnerTD,
I did some searching and found the GQ version on the internet, I have attached it to a new thread “Technical Body Repair GQ Nissan Patrol Y60” at: http://www.nissanpatrol.com.au/forum...417#post776417
I am unsure whether I was supposed to make these documents new threads or not but it seems to be the norm.
Hope it helps.
Hey MudRunnerTD,
Hope it helps.
Hahaha! There you go. it is a redirect to a Thread on THIS Forum. perfect mate.
No problems mate, it is easier for everyone to find this way.
By the way I checked out your 2010 GQ build at http://www.nissanpatrol.com.au/forum...-the-Ground-Up what a mighty effort mate, I can see why you could use body dimensions and co-ordinates, really into extreme 4wd eh!
Have a great new year playing in the mud mate! Cheers
