Results 1 to 5 of 5
Thread: Servicing the cooling system?
    May 2016
    lower west victoria
    30 Post(s)
    Planning a desert trip for later in the year.
    Vehicles's 5 years old done 140,000, sits on 88-89 mostly, seen it go up to 92 on a hot day.
    Anyway, what do I need to get done to have the cooling system serviced? Is it something I could I do with some new magical potion that's come out in the past 10 years or should I get it done by someone who knows what they're doing?
    Can a regular run of the mill mechanic do it or am I better off going to a radiator joint???
    With many thanks.
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    If you're talking full rad clean, block back flush et al, then a speccy rad dude is the go bro'.
    Although, a speccy rad dude put me onto a simple clean for the system that appears efficacious.
    Dishwasher cleaner. I shite thee not! Empty system, refill with clean water and supermarket dw cleaner. Run around as normal for a few days and empty again. Refill with water.
    Run around as normal for a bit more and empty again. Refill system with your usual water/coolant mix and off you go. Worked on my dear old gutlux. Moves quite a bit of gunge.
    Give it a shot, even if your system doesn't need looking at shouldn't harm it.
  4. The Following User Says Thank You to Touses For This Useful Post:
    0-TJ-0 (25th January 2019)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by Touses View Post
    Too much diswashing liquid.
  6. The Following 3 Users Say Thank You to 4bye4 For This Useful Post:
    GQtdauto (25th January 2019), mudnut (25th January 2019), Touses (25th January 2019)
  7. #4
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by 4bye4 View Post
    Take it out in th rain and it'd wash itself. Hmmm, intresting.
  8. #5
    Mar 2016
    Childers QLD
    22 Post(s)
    Reckon the head gasket has shat itself.
  9. The Following User Says Thank You to Touses For This Useful Post:
    4bye4 (25th January 2019)
