Results 1 to 8 of 8
Thread: TD42t loosing power
    Jan 2019
    Hobart/Albury
    TD42t loosing power
    Hey guys, I recently purchased an 02 GU with a TD42T and have only put around 4,000km on it, and one trip on the sand dunes where it got a bit hot. Since then it's been loosing power and flat spots at random RPM usually between 1.8k 2.4k, feels like it's starving for fuel. Any suggestions would be appreciated, thanks in advance.
  2. The Following User Says Thank You to 02_GU_TD42 For This Useful Post:
    dpetersen (12th January 2019)
    Expert dpetersen's Avatar
    Jan 2015
    Watarrka National Park
    3 Post(s)
    I’d get your injectors/injector pump checked out mate.
    What rpm does it sit at when idling?
    2006 4.2 tdi wagon
    TJM BullBar and bar work, Light bar & spotlights, Airtech snorkel, tradie rack, blocked egr, 2inch lift on 33s and a 3 inch exhaust to go with it all.
    Plenty more to come!
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day mate. It would help if you did an intro in the introductions and told us a bit more about yourself and the vehicle. Not sure what you were doing in the sand hill trip, but you may have blocked air filters, part blocked fuel filters or a loose connection in the fuel system letting air in now and again. from the little information you have given here it could be lots of things some minor some major. Also how hot and for how long?
    Do you own a Patrol, Maverick or Safari in Western Australia? Then this is the Club for you. http://www.westernpatrolclub.com/forum
    Jan 2019
    Hobart/Albury
    For memory around 600-650rpm, and yeah that's what I was planning to do this arvo, just need the pump timing and pressure but I don't have access to the FSM on here yet.
    Jan 2019
    Hobart/Albury
    Cheers 4bye4,
    Going off the factory water temp gauge it was about 3/4 for about 2-3 minutes, so I let it cool down at idle and I spent the rest of the day on the sand without seeing it rise again.
    In Moderation
    292 Post(s)
    Quote Originally Posted by 02_GU_TD42 View Post
    Cheers 4bye4,
    Check the little gauze filter on the inlet fuel line into the injector pump. Check all you hoses and clamps too for cracks and lose clamps. Change the fuel filter as already mentioned. 3/4 on your factory gauge is around 110c, so it’s hot but for only a few minutes would be nothing to worry about, last summer mine ran 110c for a good 5 hours towing a camper through the Snowy Mountains in 42c heat. So a few minutes is nothing.
    Bigcol (18th January 2019)
  10. #7
    Aug 2016
    strewth can they handle that sort of temp over prolonged periods? I was towing my tinny up a range during the last heatwave and it got to 100c so I pulled over until it dropped into the 90's
  11. #8
    In Moderation
    292 Post(s)
    Quote Originally Posted by cairns gu View Post
    Yeah mate it’s fine. I will admit those temps I was running and for that period had me a little concerned at the time but it got me through.
    If you see those temps, but you know on the other side of the hill you’ll get relief, just take it easy and don’t push it too hard.
