4th January 2019, 05:30 PM
Speedo not working & lack of power
Has anyone on here had the speedo stop working on a GU CRD?
Yesterday after some beach and track driving my speedo and odometer stopped working and at the same time it lost power, I am thinking it is going into limp mode because the speedo isn't working.
I have looked on the ultraguage I have connected and that doesn't show speed either but doesn't show any error code.
Have looked at what I assume is the speed sensor on the transfer case and wiring looks intact, tomorrow I will try removing it to test it, hope I am looking at the right thing.
4th January 2019 05:30 PM
4th January 2019, 05:39 PM
TPC. Check speedo pinion . Takes 5 minutes. 10mm socket . Pull the speedo pinion out and have a look if all is intact.
Linke below of my job recently.
http://www.nissanpatrol.com.au/forum...l=1#post772885
http://www.nissanpatrol.com.au/forum...l=1#post772895
The Following User Says Thank You to Hodge For This Useful Post:
4th January 2019, 05:41 PM
Other than that I know Cuppa and my mate on a GU had a wiring short somewhere in that circuit.
4th January 2019, 11:12 PM
I saw the title and I thought someone had stolen my car.
Still haven't got around to looking into this, as for the lack of power, I know what will fix mine..
5th January 2019, 04:49 PM
I removed the vehicle speed sensor and it all looks intact as does the wiring.
I connected an AV voltmeter to the sensor and spin the cog and there is no reading so it looks like it has failed as I believe I should see AC volts generated when spinning it.
5th January 2019, 05:28 PM
I am he, fear me
TPC
IIRC the speedo sensor is a hall effect device, you may not see a signal without excitation .. best check out of circuit is test the sensor for continuity, should be almost a short cct.
The Following User Says Thank You to the evil twin For This Useful Post:
5th January 2019, 06:10 PM
the evil twin
The sensor on my Patrol is a 2 wire sensor so I dont think it will be a hall effect sensor unless it is relying on the body to get the earth which would be unusual.
12th January 2019, 03:27 PM
#8
Hey Mate, have you had any joy with sorting the no speedo and limp home mode
12th January 2019, 03:49 PM
#9
PLJ
Bloody hell Paul, are you spying on me, just fixed it and drove back in after a test drive.
The Following User Says Thank You to TPC For This Useful Post:
mudski (12th January 2019)
12th January 2019, 04:00 PM
#10
The culprit was this.
Part no 25010VB000 SENSOR ASSY-SPEED METER
Easy to test, just hook up a multimeter on AC volts and turn it by hand and if it works it will show about 2.5v AC.
Cost about $150 from PartSouq.com and delivered in 4 days
Would have been an easy job if it wasn't for busting the head off the bolt and had to go buy some screw extractors.
The Following 4 Users Say Thank You to TPC For This Useful Post:
Cuppa (12th January 2019), mudski (12th January 2019), Plasnart (12th January 2019), the evil twin (12th January 2019)
