11th January 2019, 11:24 AM
How to clean up amount of wires on battery posts
I want to tidy up the amount of wires hanging off my battery posts and have a couple of ?'s.
To use a acc fuse block its a simple matter of terminating wires already in use into block and link outputs into one wire to post.
eg Spotties, ligtht bar , tray lights ,off road reverse lights ,and 2x engel pwr leads.
Winch, starter will run to battery 1 and lead off to battery 2.
Hope it makes sense, it all works at the moment just making it easier and tidier to use.
11th January 2019 11:24 AM
11th January 2019, 02:51 PM
http://www.nissanpatrol.com.au/forum...use#post767969
cheack out my post in the link above. go down and see the pics a uploaded
The Following 2 Users Say Thank You to Fireblade For This Useful Post:
dads tractor (11th January 2019), MudRunnerTD (11th January 2019)
11th January 2019, 09:55 PM
Moderator
Fireblade
Fireblade
Attachment 76374Attachment 76375
Remove all the old inline use holders and went with an ebay eBay box for $20
Led lights come on to show if a fuse is blown. Much cleaner, I’m so happy.
I also trimmed the factory fuse box lid as it was a pain to remove, it kept catching on the factory harness. Can’t even tell it’s cut but it’s so easy to remove and refit now.
Any Narva type fuse block will be fine. Run a new fused supply to the block and then go for your life mate
Check out my Toy -->
Rogue Dung Beetle
11th January 2019, 10:04 PM
Moderator
Here is some work i did on the passenger side of my GQ to make way for a new bigger airbox with through bonnet snorkel.
From This
To This.
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
GQtdauto (12th January 2019), MB (11th January 2019)
11th January 2019, 10:14 PM
Moderator
In the back of the GQ i ran a new 25mmsq supply to another fuse block for all my rear stuff
Fuse the supply and go for your life mate
Rogue Dung Beetle
Cradoka (12th January 2019), GQtdauto (12th January 2019)
12th January 2019, 11:07 AM
>mudrunner
Hi ya mate, what label maker did you use, looks very neat!
Inspired boys and thanks for the pics .
