Results 1 to 7 of 7
Thread: How to clean up amount of wires on battery posts
    May 2011
    mackay former alice boy
    I want to tidy up the amount of wires hanging off my battery posts and have a couple of ?'s.
    To use a acc fuse block its a simple matter of terminating wires already in use into block and link outputs into one wire to post.
    eg Spotties, ligtht bar , tray lights ,off road reverse lights ,and 2x engel pwr leads.
    Winch, starter will run to battery 1 and lead off to battery 2.
    Hope it makes sense, it all works at the moment just making it easier and tidier to use.
    U have 4 choices in life :U can like it; lump it; love it or shove it, take your pick and stick to it !
    Sep 2018
    queensland
    http://www.nissanpatrol.com.au/forum...use#post767969
    cheack out my post in the link above. go down and see the pics a uploaded
  4. The Following 2 Users Say Thank You to Fireblade For This Useful Post:
    dads tractor (11th January 2019), MudRunnerTD (11th January 2019)
    177 Post(s)
    Quote Originally Posted by Fireblade View Post
    Attachment 76374Attachment 76375
    Remove all the old inline use holders and went with an ebay eBay box for $20
    Led lights come on to show if a fuse is blown. Much cleaner, Iím so happy.
    I also trimmed the factory fuse box lid as it was a pain to remove, it kept catching on the factory harness. Canít even tell itís cut but itís so easy to remove and refit now.
    Any Narva type fuse block will be fine. Run a new fused supply to the block and then go for your life mate
    177 Post(s)
    Here is some work i did on the passenger side of my GQ to make way for a new bigger airbox with through bonnet snorkel.
    From This
    To This.
  7. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    GQtdauto (12th January 2019), MB (11th January 2019)
  8. #5
    177 Post(s)
    In the back of the GQ i ran a new 25mmsq supply to another fuse block for all my rear stuff
    Fuse the supply and go for your life mate
  9. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Cradoka (12th January 2019), GQtdauto (12th January 2019)
  10. #6
    May 2018
    >mudrunner
    Hi ya mate, what label maker did you use, looks very neat!
  11. #7
    May 2011
    Inspired boys and thanks for the pics .
