Results 1 to 10 of 15
Thread: Steering damper fitted correctly??
    Legendary snicko's Avatar
    Apr 2011
    Eyre Peninsula SA
    Just fitted a OME Steering damper and is the gap normal? GU 2006 Wagon.
    Also when I took the truck for a test drive it pulls a little to the left so do I need to get an alignment or will it settle in and be OK?
    GU Patrol: 3LTD :- The cheapest option is to buy the right thing the first time! - YEP WORKS FOR ME!!
    Front and Rear "LOCKED" WOO HOO !! squeal, scream, squeal toot toot !! hahahaha
    NISSAN PATROL.com.au .......stickers........done by Snicko.......I know you want one....
    http://www.nissanpatrol.com.au/forum...screen-Sticker
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Sorry i can't help u on this one snicko, but still looks wrong 2 me, is that metal on metal where the gap is???
    Apr 2011
    Eyre Peninsula SA
    Quote Originally Posted by toddrhind View Post
    No, but the shaft is tapered.
    Simpson Desert GUtsy ute's Avatar
    Apr 2011
    Forestdale Brisbane
    Hi again Snicko,
    Your damper doesn't affect your alignment.
    Try turning the steering full lock either way several times on flat ground.
    Sometimes this seems to help if they have been stored on their end for a while.
    Is the gap the end of the tapered bolt?
    If it is and the taperis nice and tight in the bracket with the nut tightened, it should be ok.
    Do you have a mechanic who could take a look for you?
    Gavin
    Apr 2011
    Eyre Peninsula SA
    I will try tomorrow the full lock trick and Monday I could take it to the ARB store I bought the damper from and get him to look at it.
    Thanks again
    Snicko
    That gap may be normal. The body of the damper looks as though it may touch the bracket if the bush was hard up against the bracket.
    Tony
    Legendary timbar's Avatar
    Feb 2011
    perth
    looks fine to me S N I C K O
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
    Apr 2011
    Eyre Peninsula SA
    Thanks guys
    Pic of finished fitting. (The gap is the same at each end.)
    While I was under there, I found a oil drip again. I asked my mechanic last time I noticed oil dripping and he said it was normal for oil to come out of the hose as it was an over fill hose? Is this what it is?? I have taken a pic so you know what I am talking about.
    Snicko
  10. #9
    Feb 2011
    perth
    dont know bout the oil drip but sounds a bit sus to me !!!
  11. #10
    Apr 2011
    Eyre Peninsula SA
    Quote Originally Posted by timbar View Post
    Thats what I thought. Hope Tony reads this as I know he will know.
