Results 1 to 10 of 11
Thread: Speedo not working & lack of power
    .......... TPC's Avatar
    63 Post(s)
    Has anyone on here had the speedo stop working on a GU CRD?
    Yesterday after some beach and track driving my speedo and odometer stopped working and at the same time it lost power, I am thinking it is going into limp mode because the speedo isn't working.
    I have looked on the ultraguage I have connected and that doesn't show speed either but doesn't show any error code.
    Have looked at what I assume is the speed sensor on the transfer case and wiring looks intact, tomorrow I will try removing it to test it, hope I am looking at the right thing.
    175 Post(s)
    TPC. Check speedo pinion . Takes 5 minutes. 10mm socket . Pull the speedo pinion out and have a look if all is intact.
    Linke below of my job recently.
    http://www.nissanpatrol.com.au/forum...l=1#post772885
    http://www.nissanpatrol.com.au/forum...l=1#post772895
  4. The Following User Says Thank You to Hodge For This Useful Post:
    TPC (4th January 2019)
    175 Post(s)
    Other than that I know Cuppa and my mate on a GU had a wiring short somewhere in that circuit.
    49 Post(s)
    I saw the title and I thought someone had stolen my car.
    Still haven't got around to looking into this, as for the lack of power, I know what will fix mine..
    63 Post(s)
    I removed the vehicle speed sensor and it all looks intact as does the wiring.
    I connected an AV voltmeter to the sensor and spin the cog and there is no reading so it looks like it has failed as I believe I should see AC volts generated when spinning it.
    IIRC the speedo sensor is a hall effect device, you may not see a signal without excitation .. best check out of circuit is test the sensor for continuity, should be almost a short cct.
  9. The Following User Says Thank You to the evil twin For This Useful Post:
    TPC (5th January 2019)
  10. #7
    63 Post(s)
    The sensor on my Patrol is a 2 wire sensor so I dont think it will be a hall effect sensor unless it is relying on the body to get the earth which would be unusual.
  11. #8
    Mar 2018
    South Oz
    Hey Mate, have you had any joy with sorting the no speedo and limp home mode
  12. #9
    63 Post(s)
    Quote Originally Posted by PLJ View Post
    Bloody hell Paul, are you spying on me, just fixed it and drove back in after a test drive.
  13. The Following User Says Thank You to TPC For This Useful Post:
    mudski (12th January 2019)
  14. #10
    63 Post(s)
    The culprit was this.
    Part no 25010VB000 SENSOR ASSY-SPEED METER
    Easy to test, just hook up a multimeter on AC volts and turn it by hand and if it works it will show about 2.5v AC.
    Cost about $150 from PartSouq.com and delivered in 4 days
    Would have been an easy job if it wasn't for busting the head off the bolt and had to go buy some screw extractors.
  15. The Following 4 Users Say Thank You to TPC For This Useful Post:
    Cuppa (13th January 2019), mudski (12th January 2019), Plasnart (12th January 2019), the evil twin (12th January 2019)
