Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: finally done it - broke my TD
    Perth WA
    61 Post(s)
    Bloody hell mate that sucks, has Mike got any ideas?
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by Woof View Post
    bin it was the first suggestion
    buy a triton was the second
    hahahahahahahaha
  4. The Following 2 Users Say Thank You to Bigcol For This Useful Post:
    Clunk (19th December 2018), Woof (19th December 2018)
  5. #13
    43 Post(s)
    Ok serious note here.
    Is it turbo'd?
    If so check the turbo to intake pipe for a lot of oil.
    You may have simply done a seal and flowing oil into the engine.
    Wost case cracked piston, bore etc.
    Either way get onto it before you hydraulic it and punch the rod out the block...
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I am hoping against hope that the bores are all ok......... just shot rings etc
    if the bores are cactii, dunno what to do then
    but I will wait until I get off my fat bum after Xmas, and start stripping it down, have engine stand & crane available for when I go to pull it out, just need to clean the car port more for more room to move
  7. #15
    Perth WA
    61 Post(s)
    Quote Originally Posted by Bigcol View Post
    hahahahahahahaha
    Yep that's Mike, always helpful hahahahaha
  8. The Following User Says Thank You to Woof For This Useful Post:
    Bigcol (19th December 2018)
  9. #16
    Try this before you get the engine full monty. https://www.youtube.com/watch?v=f9K0UFdEn_M
  10. #17
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    see the bit at 3.16, where it is spraying the crap out of the injector holes.....
    thats what mine is doing when you take the rocker cover cap off................ while its running
    chugg chugg chugg
  11. #18
    I'm hoping for your sake that it is stuck rings, so there is just massive blow past the cylinders. But having the oil way to full would be like the bottom of the pistons smashing into concrete on each down stroke. OUCH!!
