Results 1 to 4 of 4
Thread: GU Y61 Reverse Switch Hex was rounded off
    Dec 2018
    Hi Everyone,
    Need some help with removing a reverse switch off my 99 GU. It seems the previous owner had tried to remove it because I can see the hex has been rounded off.
    I can access it fine with an open spanner and enough room turn but it will damage the hex further.
    Any suggestions?
    462 Post(s)
    Vice grips....
    Endermore (23rd December 2018)
    Dec 2018
    Thank you... worked well...
  6. The Following User Says Thank You to Endermore For This Useful Post:
    threedogs (23rd December 2018)
  7. #4
    Sometimes shocking it with a tap of a hammer will break the "seal"
    or use a 6 hex socket. Good to hear you removed it ok
