Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Portable fridge/freezer temps
    WA Wheatbelt
    23 Post(s)
    What temps do you run your fridge/freezer on while you're away camping?
    I've got a 95lt EvaKool fridge/freezer.
    Thanks.
    Ross
    Aug 2010
    adelaide
    waeco 50 ltr on the third green light . turn off at night saves battery power
    as long as the beer is cold who cares lol
    OH LEATHER IS NICE
    Patrol God nowoolies's Avatar
    Perth
    g`day Ross
    i run a couple of Engel`s 1x freeze and the other one at setting 3 never failed yet (thats put the curse on it i bet)
    how long before you go away ????
    Paul
    HELL NO !!!!!!
    Oct 2010
    I have a waeco 40lt, in my old 4by I used to run at 3 degrees for fridge, -11 when I put it into freezer mode. While in freezer mode I made sure I would go for a drive atleast once a day, only for about 1/2 an hour or so, it seems to keep the battery topped up.
    Cheers Mick
    Everyone makes mistakes, the trick is to make them when no-one is looking.
    Perth
    Thanks.
    Ross
    Ross is your bus set up with solar same as mine ????? yours ex telstra?????
    HELL NO !!!!!!
    Hi Roscoe... I couldn't find an Evakool 95 on their website so I am assuming it is an 85? Anyhow I'll treat it like the Waeco 85 I had as I am sure the setup will be similar.
    (Edit - just realised your's is a Fridgemate, I was looking at the FF series)
    1. Really important... Buy a temp gauge... I use a little round sucker that stays in the fridge was about $ 5 at the Reject Shop but you can get remote reading ones if you want from Engel etc. I now use 2 X 40 litre Engels (one as frig one as freezer) and that temp gauge is worth its weight in gold
    2. I used to set my Waeco at approx -13 in the Freezer and that meant the fridge compartment was about +2 normally and + 4 (hottest). Use the temp gauge to keep an eye on temps and you will soon get an idea of where to have your settings in various modes.
    3. Now, here is the biggest drawback to the dual zone frig's. Because the temp sensor is in the "Freezer side" and also that is the only spot where the cooler plates are as well it means the Freezer side is easily controlled but the Frig side temps can wander around significantly as you open and close the lid to get gear and also as you put new stuff in (say some more drinks etc). What happens is that you can put "warm" stuff in the frig side but the Freezer just sits there fat dumb and happy AND also you can put "new" stuff in the Freezer and if the existing stuff is surrounding the temp sensor then again the thing thinks all is OK.
    4. To get around the issues what I did was as follows...
    Adding to Freezer - always put the non-frozen stuff on the bottom. Adding to fridge - always pull the top 1/2 of the divider out (or whole divider if it is one piece). Crank the Temp down a couple of degrees for an hour or so to get things happening and return to normal setting and replace divider.
    5. If you are in and out of the frig a lot around mealtimes or with the Grandkids etc I found that removing the top 1/2 divider and placing a thin material cover of pretty much anything insulated such as heavy plastic, thin teflon board or that silver reflective stuff over the Freezer section worked wonders in keeping the Frig temp down, Freezer temp stable and power useage down. Obviously when the Frig is only under minimal use thats not an issue
    6. I found the following made a big difference as well... as you knock over a tinnie or grab some drinks for everyone, replace them immediately to begin cooling rather than waiting and adding say 6 or 8 warm ones all at once. Again, the highest useage for me used to be around sundowners/tea time so I would take out the top divider at that time and pop it back at "last drinks".
    Bottom line - You never want your Frezer sitting warmer than about -12 degrees for any extended time (I like to see -15 or so). Every frig type and indeed every user will have different patterns so the Temp Gauge in point 1 is the greatest tool while you get used to how your frig reacts to daily useage. You may need to be lower than that to get the Frig section temps down tho. Juggling the divider is up to you.
  8. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    DX grunt (6th February 2011), Sir Roofy (7th February 2011), Wizard52 (16th April 2023)
    WA Wheatbelt
    23 Post(s)
    Hey ET
    Thanks for the info. It's a 95lt, came with a RC temp thingy and a wired one. It also come with a tinted perspex lid to put on top of the freezer, and the divider has holes in it for the cold air to get through to the fridge.
    Both our cameras have flat batteries and are being recharged as we speak. I'll post some pics up in the next day or so.
    Thanks for your help. Don't forget to write a book about your life's wisdom, knowledge and experience, before somebody writes your obituary. lol
    Thanks again, mate.
    Take care out there.
    Rossco
  10. #8
    Hey ET
    Thanks again, mate.
    Rossco
    Cool Banana's...
    Hey, ... Cool Banana's... Fridge.... Cool Banana's... get it?... I made a funny (well, up until Banana's hit $15 a Kilo anyway)
    With those accessories supplied you have it all mate...
    As for the book of wisdom it would be a pretty thin bastrd... now IF it was E.T.'s Book of Gutter Humour and Cracking Good Jokes I could write a Trilogy.
  11. #9
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by nowoolies View Post
    Not yet Paul.
    I looked into getting a solar panel but I haven't got a spare $900 - $1k for a 120watt panel yet.
    I've got 2 x 35w continuous amp Anderson fuses that I really need sorting out this week so I can hook the fridge up for 'Travelling Mode"
    I've also got a 750w generator that I'll be using during daytimes as a temporary fix. It only takes 200watts to run the the Evakool.
    I'm open to any suggestions. U got any pics to show, for ideas?
  12. #10
    WA Wheatbelt
    23 Post(s)
    Here's my set up in the pod on the back
