Results 1 to 10 of 13
Thread: EGT gauge probe location
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Hi guys
    I want to fit some gauges to my car.
    First question is: where is the best place to put EGT probe? dump pipe or manifold?
    How do you drill and tap a 1/8NPT thread?
    I have a high mount manifold with the provision for an external wastegate. Do you reckon I could install it in the blanking plate thats on there?
    Also, is this the line you install the boost controller and boost guage tee on? Do you put the tee before or after the boost controller in the line?
    Where do you usually run your PCV breather on top of the rocker cover?
    Td42 coily
    Quote Originally Posted by JackoGQYoot View Post
    Hi guys
    Post or pre turbo is fine. Its only a gauge for your reference.
    with a drill and a tap and die set. Lol. Sorry had to be said.
    sure why not? Looks easy enough there.
    Goes in the air intake between the air box and turbo...
    Answers in bold....
    194 Post(s)
    Go for a welded socket instead of a drilled and tapped hole in the dump pipe. There is not enough wall thickness to keep the thread from getting loose as it heats up - I know because I tried it and it failed - now have 1/4" NPT sockets, with reducing bush to 1/8"NPT in both headers for my EGT's and happy days. It cost me $50 for both sockets to be welded in at a local exhaust place and I supplied the mild steel sockets. You can buy the sockets on ebay. Check the size of the connection though as some pyro's have 1/8" on the probe and then have a special seating socket with male and female threads, hence why I have the 1/4" welded instead of going straight to 1/8"
    Oct 2017
    WA
    Thanks guys.
    @PeeBee, I'm just a bit worried about the taper thread on the egt probe. Will the tap cut it alright?
    175 Post(s)
    Usually gets dumped back into your intake. Put a catch can on it instead.
    Mate, I'm intrigued by your intake setup. Any chance of a full photo of it???
    Thanks guys.
    Tapered threads are only tapered on the male, the female thread is parallel so no worries with tapping a thread... but... on the dump you are better off welding on an adapter as prev posted.
    Best place is for the probe is the manifold, putting it post turbo means you are "guessing" the delta T lost thru the Turbo.
    Different turbo setups/manifolds/positions will have different losses
    Depends how close to the edge you want to run the engine.
  8. #7
    194 Post(s)
    As @ET says above. There is simply no meat in the dump pipe as its sheet metal. If going into the manifold watch out for swarf getting inside the engine. This goes for the drilling operation as well. If you go with the welded socket you only have to worry about the drill hole.
  9. The Following User Says Thank You to PeeBee For This Useful Post:
    the evil twin (10th December 2018)
  10. #8
    Oct 2017
    WA
    @Hodge it's just a temporary setup until I get a patroldocta airbox.😁
    http://www.nissanpatrol.com.au/forum...il-Cab/&page=3
    Yeah I will probly go pre turbo. Cause I have that blanking plate it makes it pretty easy.
  11. The Following User Says Thank You to JackoGQYoot For This Useful Post:
    Hodge (11th December 2018)
  12. #9
    Expert First Pooy's Avatar
    Mar 2018
    Well it looks like my manifold will be coming off now, I am now practically taking half the engine appart lol
  13. #10
    175 Post(s)
    Quote Originally Posted by First Pooy View Post
    What's happened mate ?
